transmission and rear end oil
Eddie Jones
07-31-2006 19:32:24
what type of oil go in it? Thank, Eddie
steve(ill)
08-01-2006 15:58:29
 Re: transmission and rear end oil in reply to Eddie Jones, 07-31-2006 19:32:24
the transmission, differential and PTO are all in the same oil system. if you have hydraulics it alsi is included. there are 3 of a 1/2 inch pipe plug on the bottom, one each cavity to drain out the oil. there is only 1 fill plug by your left foot thru a 1 inch plug on the transmission case. the best oil is a universal transmission- hydraulics fluid or HYTRANS, type fluid. you can use a straight 20 wt or 10w30 motor oil, but the addatives will cause foaming, etc if you have hydraulics. it takes about 8 quarts. you can get a 2 gallon pail at Wal Mart or farm store for $12. inside the rear wheels is a sheetmetal half moon pan that covers the final drive gears. you should remove the pans, clean out the goo, reinstall and add a quart of 90 wt gear lube to each side. im sure it needs it.
ny mike
07-31-2006 20:43:04
Im looking in the ac manual dated 1948 it says final drives sae 20w, 1.50pints, transmission sae 20w , 7 qts. thats what ac says
Eddie Jones
07-31-2006 20:01:31
 Re: transmission and rear end oil B- Allis chalme in reply to Eddie Jones, 07-31-2006 19:32:24
It a 1942 B-Allis chalmer. Need to know what type of oil go in trans & rearend. Thank, Eddie p.s. sorry about not giving all the info.
Texas Denny
07-31-2006 19:47:19
Eddie, you need to identify which tractor. They are not all the same.
