AC 160 hydraulic problems.
William Bos
07-30-2006 14:32:44
Hi,
They hydraulics ( 3 pt ) on my uncle's AC 160. They just stopped. Is ther anything that could be checked before any mojor work is done? Like filters? are the filters internal?
Thanks in advance.
Will
paul baxter
08-01-2006 13:13:23
 Re: AC 160 hydraulic problems. in reply to William Bos, 07-30-2006 14:32:44
The filter is inside the rear housing. Follow the suction line from the pump back to the housing. A small cover plate with 4 nuts allows access to the filter.
If the system is not lifting at all it might just need to be bled. Crank the tractor, rais the lift control and open the bleed screw on the pump. When fluid begins to come out close the screw. This is a common problem with this tractor when the pump gets a good bit of wear on it.
WilliamBos
08-01-2006 15:23:09
 Re: AC 160 hydraulic problems. in reply to paul baxter, 08-01-2006 13:13:23
Hi Paul,
Thanks alot for the replky. When my Aunt & Uncle get back from vacation, I will let them know. I will post back after we try this.
Thanks,
Will
