Allis C oil filter and oil
Jim Hunter
07-29-2006 07:36:55
Have a fram C159 installed is this what I should be using? Also can I use a multi weight oil ie. 10w40?
steve(ill)
07-29-2006 19:17:53
 Re: Allis C oil filter and oil in reply to Jim Hunter, 07-29-2006 07:36:55
C159 is a very good filter. you can use the multi weight oil. normally makes for better starting in cold weather. dont get too think or usage will go up. 10w30 is a minimum. 10w40- good.
old
07-29-2006 08:38:18
I run a wix fliter on my C, they chaged them again so get oil presssure back up by the way. My self I never use a multi weight oil in any of my tractors. I have better luck with oil preassure that way and I like to see the preassure guge up in the middle or higher and with mutil weights oil preassure always seems to be lower and I don't like that
Wisconsin Cowman
07-29-2006 08:22:28
Yes that is the right filter. I would use 15-30 oil. I think 10-40 will work just fine.
