need distributor battery lead terminal wd/wd45
brad in ky
07-28-2006 17:01:45
my delco remy distributor has a badly bent corroded battery terminal end ( this is the part that you connect the neg coil wire to the distrib outside, it has a nut on outside of distrib), where can I get a new one? I need this part to keep going on the tune up? Delco Remy 1111411 5m28
thanks
gene (missouri)
07-28-2006 18:12:23
 Re: need distributor battery lead terminal wd/wd45 in reply to brad in ky, 07-28-2006 17:01:45
Brass bolt and a couple of nuts from the local hardware store.
Bob
07-28-2006 17:17:57
If you can't readily find a new one, a terminal from a Delco car distributor of that era should be the same. Any boneyards nearby, with some older stuff?
I have used a distributor terminal kit from Deere, Part # AR78929, but it looks like that's been discontinued, too, unless a search would turn up a dealer who has one.
