WD front seal leaking?
MN Bob
07-25-2006 17:08:26
Started the WD this spring, Water pump leaked so parked it. Finally got a break and today I installed the a new pump, hoses, and muffler. Started right up, But- oil leaking under front end. Not sure if it is the pan gasket or a front seal. Advice?? Reason for not investigating further, yellow jackets! Story on tractor. Bob
IBorange in TX
07-25-2006 19:52:37
 Re: WD front seal leaking? in reply to MN Bob, 07-25-2006 17:08:26
I agree with Old, run it some before taking pan off. That is a cork gasket and will dry out over a period of time.
Good luck..... .
old
07-25-2006 17:49:35
See other post about your wasp problem. You may find that after you run it some the leak may go away or slow way down. Some times the hot oil/engine heat sort of fixes them BTDT and almsot didn't believe it would do so
