WD 45 belt pulley help
Dan Cychosz
07-20-2006 21:13:05
Just reinstalled the belt pulley drive in a WD 45 and I can't figure out how to disengage it, any advice would be helpful, thanx
Dave Grubb
07-21-2006 09:04:59
 Re: WD 45 belt pulley help in reply to Dan Cychosz, 07-20-2006 21:13:05
The series of holes for the engaged position are at a slightly different position from the gear end of the mounting barrel. Use a hole the gives 1/8" in/out play between the pulley rim and the frame rail when the locking bolt is tight. Make a mark on the frame rail and mounting barrel to be sure and line up on the correct hole the next time you need to renegage the pulley.
Tramway Guy
07-21-2006 07:55:07
The holes are for when it is engaged, when it is disengaged, there is a groove, if I remember correctly. It moves out about 1-1/2" I think.
There was an [aftermarket?] device to shift it from the tractor seat; I have occasionally seen it on E-bay.
old
07-20-2006 22:10:40
Well if set in all the way they run any time the clutch is out. If you don't want it to run you take it loose and pull it out some and then lock it back in. Theres a number of holes in the lock set up for engaged and disengaged.
