Unstyled WC rear hubs
Hossman
07-20-2006 17:37:43
Fellas, Just a question for anyone out there that has any time around the unstyled WC, The 37' I'm currently restorin has a "blank" hole in both the rear hubsthat is not threaded for a lug or a stud this hole is the same on both the rears it is in line with the other lugs but is just a clean hole with no threads. Im at a lost as to the reason for this just was wonderin if any body had the reason for this, have had some other questions answered on this sight about the ol unstyled. Thanks a bunch Hoss
Hossman
07-21-2006 15:14:19
 Re: Unstyled WC rear hubs in reply to Hossman, 07-20-2006 17:37:43
Thanks so much for the replys fellas,I figured it had to have somthin to do with lining up the wheels but could only guess, now I know. Thanks again, Hoss
Bill(Wis)
07-21-2006 05:24:51
MFEM is correct. The wheel hub was originally built with what we called a "mounting stud" for getting the wheel lined up right. Quite a job with tires loaded with CaCl. We widened the wheels out every June for cultivating and narrowed them up again in August. If you really think you need them, I might be able to find a pair.
MFEM
07-20-2006 18:24:19
Hello,
I believe this was used to put the wheel back on. I think it had a pin in it and it would help to put the wheel back on by getting the wheel started on this pin first. This is what I was told recently, as mine has this, too.
