wd45?
ehbh55
07-18-2006 15:01:51
I bought a allis chalmers and was told it was a wd45 but i can`t find an ID plate.Can anyone help to determine the model and horsepower.If its not a wd45 its ok.
cbp
07-18-2006 21:47:41
 Re: wd45? in reply to ehbh55, 07-18-2006 15:01:51
Not sure this is good for all years but the 45 should have an engine number that starts with 45-. As old said, the engines are too interchangable for that to be definitive on the tractor itself. A WD engine number is probably going to start with just WD or U for the earlier ones.
old
07-18-2006 20:41:26
One way to tell if its has a WD or WD45 engine is to look at the right side of the block. If it has a cover that bolts on it has a WD engine. If it doesn't have a side cover then it has a WD45 engine but either way it could still be a WD or WD45 since both engines bolt up to either tractor.
54 AC
07-18-2006 19:14:40
The serial number is stamped into the rear cover just below the left side brake housing . I used a paint remover to get the paint off to read it because it is very shallow stamped.
piston
07-18-2006 18:16:57
 WANTED NICE WC OR WD PULLER in reply to ehbh55, 07-18-2006 15:01:51
WANT SOMETHING STRONG AN DEPENABLE, AROUND 3 OR 400 CUBICS, WILL PAY CASH
Don L C
07-22-2006 23:51:41
 Re: WANTED NICE WC OR WD PULLER in reply to piston, 07-18-2006 18:16:57
Look on "Photo Ads" ..... .there was 2 for sale one had a differnt engine for pulling....
Put WD-45 in search see if they come up....
BJKA
07-18-2006 20:45:42
Where are you located? May be able to help.
email me if you'd like
piston
07-20-2006 20:17:20
 Re: WANTED NICE WC OR WD PULLER in reply to BJKA, 07-18-2006 20:45:42
well i did email you still waiting
AaronSEIA
07-18-2006 15:51:51
Check the picture page here to see what it looks like. WD or WD45 has the tractor serial number on the rear of the tractor, left side of the diff housing by a hole in the casting, starts with WDxxx. WD had somewhere around 30 horse, WD45 had something like 40 ish.
Aaron SEIA
