E
nate
07-08-1998 20:14:05
What does anyone know about a Gleener model E.
grapeape
07-10-1998 11:00:32
 Re: E in reply to nate, 07-08-1998 20:14:05
: What does anyone know about a Gleener model E.
what would you like to know? they were a great seller when they were new, my dad couldnt keepem on the lot. they came out cabless and handled usually around here a ten foot grain platform and a two or three row corn header. they were tough little combines that worked well and put a clean sample in the bin.
keith
07-09-1998 18:19:20
i know that the engine is basically a D17 motor with heavier main bearings. it has larger valves than the wd45, and a higher compression ratio. i freind saw one go at an auction for $250. he wished he'd bought it!
Dan D.
07-15-1998 15:27:19
 Re: Re: E in reply to keith, 07-09-1998 18:19:20
: i know that the engine is basically a D17 motor with heavier main bearings. it has larger valves than the wd45, and a higher compression ratio. i freind saw one go at an auction for $250. he wished he'd bought it!
The engine in an E is a D-17 motor period. They did have a higher compression ratio in the later ones (8.0 :1) like they put in the 170's. However, there is no difference in the main bearings..I've worked on these engines both out of tractors and combines and the bearings are identical.
