confused about firing order on 37 WC
rich in ny
07-16-2006 09:00:23
I am a deere guy owning a 51 a and a 56 70D but the price was right so I bought a 37 allis wc. According to a stamping the firing order goes 1243. But a trusted tractor repair shop says that number 1 is closest to the radiator. We set it up according to the tractor repair shop and got it to run but rough. What is the correct firing order? I think the stamping is right myself. Please help
old
07-16-2006 09:23:06
 Re: confused about firing order on 37 WC in reply to rich in ny, 07-16-2006 09:00:23
1,2,4,3 is correct and yes the #1 plug is at the front of the engine rad. end. Common problem is that you get rotor turn back wards and if you did then you will have a couple wire mixed up. You need to double check which way the rotor turns by removeing the cap and then turning the engine, unless you have a mag then don't or you can mess up the timeing of the mag. You also might take 2 wires and switch them from one side of the cap to the other side. Do that with wires 3 and 4 whcih are the one you probably have mixed up. BTDT more then once. Shoot on an Allis C I have I had trouble and moved each wire around by one and it started right up so I was just lost as to where #1 was on the distubutor cap
