Allis WD45 Choke Control
Toby Wellborn
07-15-2006 14:26:00
Could someone send me a photo of how a Allis WD45 Choke is hooked up?
old
07-15-2006 14:58:50
 Re: Allis WD45 Choke Control in reply to Toby Wellborn, 07-15-2006 14:26:00
I knew I was forgetting something LOL. Also not sure taking a picture of it would really help since when I tried the thing didn't show up well. I'll try to expalin and then go from there. The choke rod hooks to the left side if the steering colunm and then goes down the right side and under the tank. From there it goes to a rod that goes through the tank mount and over the a lever on the left side and down to the carb. Theres a lever on both sides of the tank and on my WD45 both levers point down. Does that help any??
Toby Wellborn
07-16-2006 08:44:41
 Re: Allis WD45 Choke Control in reply to old, 07-15-2006 14:58:50
Does not help... I just need a photo...
The choke shows two rods and a spring.
Mine has been rigged and only has one rod and a spring hooked to the coolant drain cock.
Want to make it original...
old
07-16-2006 14:31:15
 Re: Allis WD45 Choke Control in reply to Toby Wellborn, 07-16-2006 08:44:41
I'm going to post a picture of the choke rod in parts and pieces but I don't think it is going to help since you can't really see it well
old
07-16-2006 09:11:44
Yep two rods. One from the carb choke to the lever under the tank and the other from the lever on the right up to the steering colunm. The spring is ate the carb and hooks to I don't remember. I'll give takeing a picture anoture try many with it being hot and sunny it will work. The other day when I did it I did it between rains
