All Crop Harvester
fat phil
07-13-2006 07:47:59
I have a old all crop harvester.Are there any serial # plates on this thing so that I can find out what model it is?
Leroy
07-13-2006 17:53:01
 Re: All Crop Harvester in reply to fat phil, 07-13-2006 07:47:59
The number is stamped in the angle iron on the back side bottom of strawwalker on the left side of machine, about 2 feet from left side. If the platform is just as wide as canvas then it is a 60, if a flair to platform of 3" on each side a 66, if a 5' cylinder with auger a 72, if a 4' cylinder a 90. the number is width of cut, count the number of sections in knife and multyply by 3" per section. 20 sections is 5' for a 60, 22 is 5 1/2' for a 66' cut and so on. Dow if it is a straight thru machine it is a 40 or the selfpropelled is a 100
Butch(OH)
07-13-2006 08:05:53
No plate but assuming you dont have a model 40 or a corn belt combine the serial number will be stamped in the frame on the left side, above the wheel and below the cylinder,in front of the straw rack about belt high right at the bottom of the sheetmetal. Can get a picture if need be.
730virgil
07-14-2006 21:00:22
 Re: All Crop Harvester in reply to Butch(OH), 07-13-2006 08:05:53
butch are you coming to il for ac ted allis show in august ? this will be the 10 th year , ted says will be his last time
