Exhaust manifold gasket for a WD 45
Frank
07-08-1998 19:50:21
Where can I find just the exhaust manifold gasket and not the whole set of gaskets for the WD 45?
orangeman
07-09-1998 07:34:31
 Re: exhaust manifold gasket for a WD 45 in reply to Frank , 07-08-1998 19:50:21
Central Tractor lists the manifold gasket set for a wd-45 at $12.29. There are multiple gaskets so you really do need them all. Central Tractor 1-888-828-3276.: Where can I find just the exhaust manifold gasket and not the whole set of gaskets for the WD 45?
Dan D.
07-09-1998 07:40:31
 Re: Re: exhaust manifold gasket for a WD 45 in reply to orangeman, 07-09-1998 07:34:31
: Central Tractor lists the manifold gasket set for a wd-45 at $12.29. There are multiple gaskets so you really do need them all. Central Tractor 1-888-828-3276.: Where can I find just the exhaust manifold gasket and not the whole set of gaskets for the WD 45?
I think they're a little less than that right from AGCO. That kit conatins extra pieces as it's the one also used for the 6 cylinder tractors. So, two kits from AGCO would be enough to do three four cylinder tractors. Also, if you romove the manifold to put in new exhaust gaskets, it will ruin the intake gaskets so you'll need those, too.
grapeape
07-10-1998 11:33:59
 Re: Re: Re: exhaust manifold gasket for a WD 45 in reply to Dan D., 07-09-1998 07:40:31
: : Central Tractor lists the manifold gasket set for a wd-45 at $12.29. There are multiple gaskets so you really do need them all. Central Tractor 1-888-828-3276.: Where can I find just the exhaust manifold gasket and not the whole set of gaskets for the WD 45?
: I think they're a little less than that right from AGCO. That kit conatins extra pieces as it's the one also used for the 6 cylinder tractors. So, two kits from AGCO would be enough to do three four cylinder tractors. Also, if you romove the manifold to put in new exhaust gaskets, it will ruin the intake gaskets so you'll need those, too.
if you will use high temp "red" rtv on the gaskets during installation it will almost guarantee a problem free seal. put a light bead between all the layers of the gasket, even on the metal portion that will come in contact with the cylinder head. it also makes it easier to hold them all together while youre gettin it together. goodluck, grapeape
grapeape
07-10-1998 11:33:55
