WD - foot clutch actuating rod - straight or sligh
ShepFL
07-13-2006 06:27:07
The WD that followed me home has a hiccup. Clutch pedal likes to SMACK the he11 out of my lower shin, just above the ankle. 3 strikes & your out!
Originally thought when pressing down on clutch pedal the actuating rod was hanging up on the inside of the slab rail frame. Looking closer I see the clutch pedal moves past the built in stop located on the frame.
There is some side play in the pedal mount but do not see a way to tighten that so . . .
I am thinking of taking the actuating rod off and putting it in the press to make it straight vs. slight bend. I am risking premature clutch failure by doing so?
Thanks
Teddy (punchie)
07-14-2006 19:32:52
 Re: WD - foot clutch actuating rod - straight or s in reply to ShepFL, 07-13-2006 06:27:07
Add a shim or a washer to the outside and replace the cotter pin. Some times you can get a peace (sp) of copper pipe or conduit and use it for a shim and greaces it from time to time. Have fun !! Teddy
alliswdman
07-14-2006 05:07:38
i have wd and i have same problem thats why i use hand clutch it it works graet and less foot work the only time i use foot clutch is to put in pto gaer and first start out than shift with hand clutch i bale hay with it and i love it i use a 310 new hollen with thrower wd,s have a lot of power almost cann,t believe it can run that baler but it does
JMS/MN
07-13-2006 09:11:14
The only sure cure is some machine work, to get it back to new. The pins the clutch and brake pedals pivot on are replaceable, but the pedals themselves need to be bored out and a bushing installed, matching the new pin. Good for another 50 years.
Butch(OH)
07-13-2006 07:20:16
Hey, I have felt your pain, litteraly. I am not sure how bending the rod from the clutch pedal going forewards would fix or even rig this problem? The fix is to repair the clutch pedal bushings and shaft so the pedal wont go out past the stop. If jury rigging it is the way you wish to deal with it then you have options. Grind the stop back so the pedal doesnt catch it at all or bend the pedal so it can"t go by the stop even with the slop or add a stop to the top of the frame rail to stop pedal travel. Have seen all of these riggings work.
ShepFL
07-13-2006 08:50:00
 Thanks Butch in reply to Butch(OH), 07-13-2006 07:20:16
I am always inclined to make the repair the right one vs. jury rigged. Over the yrs. and thru the school of hard knocks I have learned a few critical truths:
1. If you don't take the time to fix it right the 1st time you must make time to fix it a 2nd time
2. The 2nd time fix will happen at the MOST inoppurtune time (criticality meter is PEGGED!!)
3. Good ain't cheap and cheap ain't good!
Thanks and & grins from here,
ShepFL
old
07-13-2006 08:57:49
 Re: Thanks Butch in reply to ShepFL, 07-13-2006 08:50:00
Pretty common problem on the WDs and look at your brake pedels and you will probably find they also have a lot of side to side play. I know both my WD and my WD-45 have the same problem with both the clutch and the brake pedels. Shoot on one of them if you hit the right brake the pedel will hang on the fender and not come all the way back.
