AC Grader
Deepwoods
07-12-2006 10:39:18
I'm trying to get any info I can on this grader I just bought. Serial # is D-5875. It's a 4 cyl. gas. The only # I found on the block is behind the oil filter and is AM 4660. The motor needs to be rebuilt as well as one valve pushrod(its bent), but I don't know what motor I have. Any help would be great.
Thanks
Andrew
Don BC
07-12-2006 16:42:45
 Re: AC Grader in reply to Deepwoods, 07-12-2006 10:39:18
Tony is correct. My model D grader has s/n 5554 and is a 1960. It has the popular Allis D17 tractor engine and the engine parts are readily available. You can email Tony to check for parts. What options are on your machine? i.e, cab, power circle, ripper. I have a parts manual for this series. Email me if you have questions.
Tony Carbaugh
07-12-2006 15:35:21
Andrew . You have a 1961 grader. It should have a D-17 engine . Tony
old
07-12-2006 11:04:00
The number doesn't say much to me but I also don't have any books with numbers. But if you go to my web site and you look at the grader I have and if your is the same then I can help you. Let me know if your is the same or not
