CA HYD fit a C???
shawnspeed3
07-12-2006 09:26:44
was curious if it is possible to install a CA PTO housing/hyd pump on the B/C series tractor, or are the internals/pto housing different???anybody attempt this conversion????shawn
D13
07-13-2006 08:07:59
 Re: CA HYD fit a C??? in reply to shawnspeed3, 07-12-2006 09:26:44
If you take the entire CA housing and pump, yes.
CA uses 4 pistons and B/C use 2, but the complete housings will swap (my B's have CA housings).
Assuming you have either no housing or a non-hydraulic housing (no plate on the right side), you just need to be sure that the both the new housing's PTO shaft and the pump have the same number of lobes (2 or 4. If you have a housing with a plate on the RH side, remove it and check how many lobes you have, then get the appropriate pump (about $250 rebuilt). Some later tractors have the provisions but no pump.
If you have a
Sid
07-12-2006 19:28:32
As I understand the shop manual the B and C pump is a two piston pump while the CA has four pistons. I doubt it would work.
shawnspeed3
07-12-2006 12:34:18
I could be interested ,about what are you lookn'for price wise????shawn
old
07-12-2006 14:39:21
 Re: CA HYD fit a C??? in reply to shawnspeed3, 07-12-2006 12:34:18
Drop me an e-mail and I'll discuss price with you I don't like to do so on the board
old
07-12-2006 10:19:38
I can't tell if it can or can not be done but I do have a hyd set up on a parts C I'd sell if you find you can't. E-mail is open
