Wd45 pops out of 4th gear
bebert
07-09-2006 13:26:10
I have a 1953 wd45 and when driving in 4th gear it pops out of gear whenever you move the throttle and speed the engine up or down. I try holding it in gear but it does not help, it still pops out. All the other gears drive good and 4th seams to go into gear just as easy as the others. Any suggestions?
dirt farmin
07-16-2006 10:03:49
 Re: Wd45 pops out of 4th gear in reply to bebert, 07-09-2006 13:26:10
first,dont ever put that thing in fourth gear cause your taking your life in your own hands unless your on a super flat surface and its awful tough on the gears.3rd gear is fast enough on an AC, even 2nd if you got a tricycle.It sounds like a bad syncro,a lot of money to fix that.
old
07-09-2006 16:17:06
Shifter not shifthing it all the way end, bad bearings some place.
