Question about plug wires on Allis B
Tim in NC
07-08-2006 17:00:23
On an Allis B magneto looking at the rotor cap what is the firing sequence, say starting in the upper left had corner. Thanks
Tim
Dick L
07-08-2006 18:57:56
 Re: Question about plug wires on Allis B in reply to Tim in NC, 07-08-2006 17:00:23
Try this!
third party image
Rod (NH)
07-08-2006 17:23:53
Hi Tim,
It's 1-2-4-3 clockwise looking at the cap and starting at the upper left terminal.
third party image Rod
Skibo
07-08-2006 17:19:09
It doesn't matter. Mags fire one terminal after the other. So starting at ANY terminal, the mag "firing" order is 1-2-3-4. Confusing? Not really. Hook your respective spark plug wires up in the correct firing order and you're good to go. So if your firing order is 1-3-4-2, hook your first wire up to any terminal, and then 3, then 4, then 2 after and in that order and you're done.
DaveInMI
07-09-2006 03:38:33
 Re: Question about plug wires on Allis B in reply to Skibo, 07-08-2006 17:19:09
I think you should check to see that the piston is coming up on the compression stroke instead of the exhaust stroke when using this method.
Skibo
07-09-2006 06:32:57
 Obviously. in reply to DaveInMI, 07-09-2006 03:38:33
