WD Hydraulic Rams Rusted in the up position
Will Herring
07-07-2006 06:34:20
Basically, it's as my subject line says. Can I attempt to sand them down smooth so they'll work again, or do I need to get new ones or take them to a shop... Or what? They're not in TOO bad of shape, but they won't go up and down anymore.
old
07-07-2006 12:36:56
 Re: WD Hydraulic Rams Rusted in the up position in reply to Will Herring, 07-07-2006 06:34:20
My self I wouldn't use sand paper but I would use emery cloth, leaves less stuff behind and sand and hyds don't mix well. If you find you need one or 2 I may have them, on a parts tractor that I have
John (MO)
07-07-2006 07:07:54
Sure you can try, what have you got to lose. If they aren`t really pitted, you should be ok. You can also pick up used ones, they usually aren`t too expensive.
