D-17 Exhaust manifold leaks
Rngr
07-06-2006 19:24:35
Second set of exhaust manifold gaskets I have put on and the same one keep leaking. Seems to blow the gasket, for lack of better words on the left side. Each time I put a new one in it blows part of it out (not the metal gasket but the fiber one that goes inside the metal gasket). Is there some sort of trick or something I am doing wrong?
rngr
07-07-2006 05:57:37
 Re: D-17 Exhaust manifold leaks in reply to Rngr, 07-06-2006 19:24:35
Thanks for the replies. I'll check both.
BCnT
07-06-2006 20:51:00
sounds like either the manifold or the head isnt flat...check em both with a straight edge for waviness and pitting
JMS/MN
07-06-2006 22:04:27
 Re: D-17 Exhaust manifold leaks in reply to BCnT, 07-06-2006 20:51:00
Agreed- needs to be refinished on a surface plane. All of those surfaces need to line up, or the gaskets do not hold.
