model M engine miss
jackwelder
07-05-2006 23:00:53
number 1 cyl has spark but not firing.pulling plug wire off # 1 while running does not change speed.2,3,4 fire OK .all cylinders have good compression.recent valve job.new magneto.something weird here.idle adjustment at carb not responsive.high speed adjustment is.cant find air leaks outside of manifolds.
Jerry Coulter
07-06-2006 05:11:33
 Re: model M engine miss in reply to jackwelder, 07-05-2006 23:00:53
Try switching the plugs around and see if the miss follows a defective plug.
Over years past, we had to replace tubes inside several of the UM301's manifold. When it rusts through, the intake and exhaust gases mix causing the engine to run in a heavy gasp and spurt.
jackwelder
07-06-2006 07:26:36
 Re: model M engine miss in reply to Jerry Coulter, 07-06-2006 05:11:33
I did do a plug switch with no change.The manifold sounds very suspect.I did not find any exterior leaks at the manifold.I will check that out today.Your discription of a gasp and spurt is right.I Am helping out a retired welder who has done a beautiful restoration.He and a few others have been puzzled along with me.I looked at carb and ignition and compression yesterday.Thanks a lot. Mike williams
