AC WD zenith carb
sgtbull
07-05-2006 20:55:16
Can anyone tell me where to get parts for a Zenith carb for a WD? Specifically, the venturi, and the idle jet orifice.
Glen in TX
07-06-2006 15:02:21
 Better view of 68 series in reply to sgtbull, 07-05-2006 20:55:16
third party image
The 12522 which is a 68 series only has a discharge jet and main jet and idle adjusting jets.
sgtbull
07-07-2006 10:19:06
 Re: Better view of 68 series in reply to Glen in TX, 07-06-2006 15:02:21
I appreciate your response...I was able to locate a good used carb at a nearby dealership, who sold it to me for $5.00 Couldn't beat that, and i'm in good shape now.
Glen in TX
07-07-2006 11:51:09
 Re: Better view of 68 series in reply to sgtbull, 07-07-2006 10:19:06
Good deal! Those jets are about $18-$30 anyway.
Glen in TX
07-06-2006 14:59:39
 Re: AC WD zenith carb in reply to sgtbull, 07-05-2006 20:55:16
third party image
The 14991 which is a 267 model series would have a idle jet. It should be available. I put illustrations of 267 and 68 series on parts & pieces gallery. You should be able to copy or save them and blow up to view better as a jpg pic. If not email me.
Glen in TX
07-06-2006 14:21:34
third party image
I would have to know the 5 digit number off the aluminum Zenith or other numbers off the cast iron Zenith. Some are those parts aren't available and some are depending on which number you have. Common Zenith aluminum carbs that may be on it are 12522 universal type or 14991. They didn't use a idle jet but had a discharge jet and adjustable main jet assembly. Venturis are in price sheet for those two and jets may be available yet also. Not the best view of a Zenith carb but if you need a better view email.
