hd-5
shirewoods
07-05-2006 10:07:17
I have an HD-5 from the 50s and I don't know how to check the transmission fluid. How do you check the transmission fluid? The left side track keeps coming of the front roller and it takes me about 4 hours to get it back on. How can I prevent it from coming off? canI weld a rib on the roller? Is there an easy way to put it back on when it comes off?
hectorgemme
07-05-2006 15:04:56
 Re: hd-5 in reply to shirewoods, 07-05-2006 10:07:17
HI The old one had no oil gauge and later on have one on the transmission plate cover right side and for the chaine she must be too loose and you need 1 inch loose you have to adjusted the chaine by the big screw betwen the idler and the tension spring.
big hunter
07-05-2006 14:12:52
don't know how that machine is set up but you must have something worn out (needs to be replaced) or you have too much slack in the tracks (tighten them)
