WD45 Front End
Fredd
07-05-2006 06:58:10
I got to noticing that the steering wheel was getting especially hard to turn so I took the plate off the front and found no gear oil. Also the roller bearing that is toward the steering wheel end of the shaft behind the worm gear where the shaft goes through the cast iron is clear worn out. I put some gear oil in it and it ran back out through the bearing.(Darn) I bought a WC a while back for parts for mine, and the motor. I was wondering if I could just take the front end off of the WC and put it on the WD45?? The key on the front end of the WD45 is also worn to the place where the wheels flop, this is another reason for replacement.
JMS/MN
07-05-2006 07:30:50
 Re: WD45 Front End in reply to Fredd, 07-05-2006 06:58:10
They will interchange.
