stuck engine
Jim Emery
07-05-2006 06:40:21
I have a AC-CA that has been sitting for about a year in the shed. Now engine is stuck. What is the best method to free it up.
Thanks.
old
07-05-2006 09:16:40
 Re: stuck engine in reply to Jim Emery, 07-05-2006 06:40:21
Well as RC has said and this is what I use and has worked on all but one engine so far and I play with/buy a lot of tractors with stuck engines. Pull the plugs, fill the cylinders with tranny fluid. Let if sit a few days then with a good battery and the plug out hit the starter button, don't hold the boyttun just give it short quick hits and watch the crank shaft pulley. If it moves any at all just keep hitting it and it will most likely pop free. You still may have to remove the valve cover because of a valve sticking, I've had to one 2 enignes out of around 7 or so and as I said only one engine didn't pop free, but thats another story
RC farms
07-05-2006 07:30:04
fill up the cylinders with transmission fluid...let it sit for a few days and try to turn it over with the starter...without the plugs in...must give credit to Old for this one... it worked for me. I was warned by others about pulling the tractor in gear...if there's a stuck valve it's possible to bend a push rod. Don't try hammering on the crank handle...I sheared off the crank pulley woodruff key on my C now I'm fixing that...not fun.
