d-14coolant leak
chris stencil
07-04-2006 09:16:21
I have a 1959 d14. I have replaced all radiator hoses,check radiator for leaks,no luck. I moved fan blades and it is very wobbly loose,there was the leak every time I touched it. What do I do to tighten up situation?
JMS/MN
07-04-2006 12:26:37
 Re: d-14coolant leak in reply to chris stencil, 07-04-2006 09:16:21
Water pump bearings and seal went kaputnik! Sloppy fan shaft is the giveaway. Rebuild/replace.
