How to attach drawbar AC Model B
malamute
07-03-2006 18:09:46
I just purchased a 52 AC model B. It came with the drawbar, but it isn"t mounted, and there isn"t any hardware for mounting. Does anyone have any pictures/ideas on how to attach it?
Thanks.
Pappy
07-06-2006 19:14:37
 Re: How to attach drawbar AC Model B in reply to malamute, 07-03-2006 18:09:46
There is a set of these drawbar mounting clips on EBay now. Look up # 140005015440.
No---this is not my auction. I have no interest in this item. Just for information.
Pappy
07-04-2006 15:47:55
Log on to EBay and look at auction number 3300034333746
You will see the drawbar retainers. I believe they are shown clearly enough for you to get the idea how they work.
malamute
07-04-2006 17:10:54
 Re: How to attach drawbar AC Model B in reply to Pappy, 07-04-2006 15:47:55
I found the subject auction. It's pretty clear. I think I may need to bid on it so that I can get the retainers. Thanks for the help.
malamute
07-04-2006 17:03:15
That EBay auction ID turned up zero results. Maybe the auction ended already. I think part of the problem is that I do not have the retainers. I guess finding a set will be my next challenge.
Mark in NC Iowa
07-06-2006 08:45:47
 Re: How to attach drawbar AC Model B in reply to malamute, 07-04-2006 17:03:15
There is another set of retainers on ebay
140005015440
runs out on July 12th.
You may need them more than me as my belly mower brackets may force me to improvise.
Mark
old
07-03-2006 18:29:56
The draw bar hooks up with a pin and bolt set up. The pin goes in the back most hole and then the bolt goes in the front hole. The pin has a flat bar that the bolt holds
