AC B rear axle (drive shaft) seal??
Mark Kluber
07-03-2006 16:58:17
I have a "39 B that needs a new seal on the rear axle. I pulled the wheel and the seal is directly behind the wheel. It looks like there are 3 rings, not sure which one is the seal and how do you get them out? Is one a retainer of some kind?
Any advice on putting the new seal and other parts on?
Do I need to check the bearings--- I think the bearings are farther in aren"t they?
If any one has pictures they can share of this process that would be great. Thanks,Mark
Pappy
07-04-2006 15:16:29
 Re: AC B rear axle (drive shaft) seal?? in reply to Mark Kluber, 07-03-2006 16:58:17
Pry the oil seal out using a big scewdriver or other suitable tool. Don"t scratch the shaft. You might consider drilling a couple of holes in the metal part of the seal. Don"t go deep, just through the seal. Once the seal is popped out, you will see the bearing just below the seal.
