WD45 Coil Resistor?
MikeRW
07-03-2006 05:40:55
Just got my non running wd45 running with the help of cleaning the fuel system and replacing plugs, points, wires, and such. The new 6 volt coil i put on has it printed on the coil that it needs a resistor. There was no resistor on the tractor when i bought it and i don't see one in the wiring plans nor do the materials i have refer to one. Should it have one and if so is there a part #. Any input is appreciated.
BCnT
07-03-2006 06:18:57
 Re: WD45 Coil Resistor? in reply to MikeRW, 07-03-2006 05:40:55
if youre still running a 6 volt battery you dont need a resistor...if you upgrade to a 12 volt system you need a resistor between ignition switch and coil...i use one off a '58 ford f-250 since it has a metal mount ... a chrysler product porcelain resistor works too.
