Refilling LP Tanks
TWM-MN
07-02-2006 12:17:05
I would appreciate some advice on how this is done or can be done. New to LPG tractors--care to share any experiences or information?
Mark - IN.
07-04-2006 12:34:00
 Re: Refilling LP Tanks in reply to TWM-MN, 07-02-2006 12:17:05
Just be careful. When I was a kid, a neighbor had an LP Case. He used to fill his own too, but one day made a mistake or got careless or stupid or... Whatever happened in that barn never happened again. The barn got leveled and so did he. The LP tank was ground zero and he did smoke cigars, so maybe 1 + 1 = 2 in his case. No one really ever did know, but his widow did find one of his fingers while mowing the lawn a week or so later. He sure did something he wasn't supposed to.
Like anything else, Im sure it's easy enough so long as you're careful and do it like you're supposed to.
Mark
Kent of SW MO
07-02-2006 14:19:45
I just got done doing this several times this Fescue season on my LP fuel C-II Gleaner with a G-262 power unit. I have a LP pump powered by a 4 HP B&S Motor. I also have a trailer mounted 250 gallon tank to nurse from. Almost all residential tanks have a place to draw liquid from. You will need a special fitting and a valve to be able to tap the liquid. You will also need a fill hose with the fitting to fit the fill fitting on the LP tank. If you do not have a pump you can fill by connecting a hose from the liquid tap on the supply tank to the tank you are fill. Then you must some how lower the pressure in the tank being filled. The easy way to do this is run the tractors engine with only the VAPOR valve open. This will take a while to fill the tank but it will fill the tank. Another way is to cool the tank being fill some other way like with maybe a CO2 fire extinguisher. It is not a bad practice to have a fire extinguisher around even if you do not us it to cool the tank being filled. You will also need to open the liquid level ( dribble valve) to know when the tank is full. It is full when you get liquid at this point which is the 85% level of the tank.
Kent
TWM-MN
07-03-2006 07:23:26
 Re: Refilling LP Tanks in reply to Kent of SW MO, 07-02-2006 14:19:45
Man, what did I get myself into? :-)
Don"t have any sort of pump. I just thought that I could run a supply off the big grain dryer tank or the furnace tank into the one on the tractor. I"m not even sure where it would be filled into on the tank on the tractor. I might have to call the Coop to come out and fill it up, then take note of how they do it.
Thanks
John (C-IL)
07-03-2006 10:20:27
 Re: Refilling LP Tanks in reply to TWM-MN, 07-03-2006 07:23:26
It is tricky and dangerous business to fill a vehicle tank from the delivery truck because it has a high volume pump.
Call your coop and they will be able to set you us with a liquid withdrawl valve on your home heating tank with a hose and the correct adapter. When you fill the tank you can open the liquid level gauge and the tank will fill from the storage tank. UNDER NO CIRCUMSTANCE should you let the tractor run while you are filling the fuel tank. Remember that LP gas is heavier than air and will flow down from the point where it is released which means that it is possible for the gas to flow past the ignition system on your tractor and potentially cause a fire.
Kent of SW MO
07-04-2006 09:37:58
 Re: Refilling LP Tanks in reply to John (C-IL), 07-03-2006 10:20:27
After you have all the connections made and there ARE NOT ANY LEAKS, you can run the engine from the vapor valve and this will cause the tank to cool because the liquid LP is boiling to replace the vapor in the vapor space of the tank. When the tank cools the pressure is lower and the liquid LP from the supply tank will SLOWLY fill the tank on the tactor. I did this on a Allis B-112 that had been converted to LP with a small tank that did not have a standard fill valve. All it had was a 3/8 copper flare liquid and vapor valves. I connected a standard 20 LB bottle to the liquid valve and turning the 20 LB upside down to feed liquid. I then started the B&S engine which was drawing fuel from the vapor valve. This filled the tank on the mower. You should note that yes LP vapor is heavier than air but almost any wind is enough to disperse the vapor removing any danger from a filling operation. One other point if it is so dangerous to run the engine while filling a tank, what about the engine on the tanker truck that is running to power the pump that is filling a tank when you have LP delivered? Yes sometimes this truck is some distance away but when I had some fuel delivered to the field 10 days ago the engine on the tanker truck was with in 25 feet of the tank on my combind and the tank on my header trailer. I have never seen a minimun distance spec. between the tanker truck and the tank being filled. Kent
504-1
07-07-2006 16:32:46
 Re: Refilling LP Tanks in reply to Kent of SW MO, 07-04-2006 09:37:58
You do not fill your car while running, do not fill L.P. while running.( I fill about a hundred 33# a day)
TWM-MN
07-03-2006 11:05:14
Thank you!
I had someone speak with the LP delivery man and he is going to show us how to fill from our dryer tank when he comes out to do summer fill in a couple weeks.
How far can I trust running the tractor by viewing the gauge on the tank? Can I go down below 5 on the tank?
