CA voltage cut-out relay / voltage regulator
SM Miller
07-01-2006 15:36:37
We have a restored CA and the Voltage Cut-out relay needed replaced. I ordered the wrong part and I got a voltage regulator instead. Since I have the regulator in hand I would like to use it. Also my 82 year old father-in-law and my 17 year old son want to drive their CA together for the first time in a 4th of July parade. On the surface it would seem that the regulator would work better than a cut-out relay. I have a complete wiring diagram for the generator / cut-out relay. However I have no wiring diagram for the generator/ voltage regulator system. Does anyone know if this is even possible?
steve(ill)
07-03-2006 07:58:30
 Re: CA voltage cut-out relay / voltage regulator in reply to SM Miller, 07-01-2006 15:36:37
the cutout version has the "F" on the generator going to the resistor on the light switch. you will not use the swithc any more.----- take the regulator (hopefully it has 3 terminals B,F,G). mount the regulator to the generatoro, take two short wires about 8 inches long and connect the regulator F to the generator F, connect the G to the generator A, connect the old cutout - out wire goes goes to the ampmter to the B terminal on the regulator.---- the old F wire off genrator to the light swithc, just tape off.----- if your regulator has a L terminal, that is suppost to be HOT when running, normally comes from the ignition switch, IT IS NOT THE LIGHT SWITCH wire.
