transmission and hydraulic
big hunter
06-29-2006 16:54:45
I have a CA. kinda dumb question but here goes, is the transmission and the PTO/hydraulic fluid all in one. I found the drain plug back under the PTO housing and another drain plug under the trans housing. the only fill hole that I can find is the little dipstick on the opposite side of the trans gear shifter. the hydraulic calls for 20 weight, does the trans take 20 weight also. I thought gears took 75/140 or there about.
old
06-29-2006 18:29:19
 Re: transmission and hydraulic in reply to big hunter, 06-29-2006 16:54:45
Can't say for sure on a CA but on my C its the same oil for the tranny and hyds and the rear end. I use a universal tranny/hyd fluid in it
