WD45 Steering adjustment
R. Freshour
06-28-2006 20:34:28
Is there a way to adjust the steering to get rid of excessive play without buying new gears? The u-joints are tight. Ihad the front plate off and saw there was a bolt in the grease on the segment gear. Is this a set screw or an adjustment? (Haven"t had time to tear into it yet). Thanks.
wddave
06-30-2006 07:00:55
 Re: WD45 Steering adjustment in reply to R. Freshour, 06-28-2006 20:34:28
There are shims to adjust the end play on the worm gear shaft. If taking out shims isn't enough then take the shaft out to see if the spacer is worn too short. Also the pin hole in the shaft for attaching the worm gear can be worn. The shaft is soft steel so making a new one if necessary is easy.
JMS/MN
06-28-2006 22:54:04
Do you notice more wobble on a hard surface, as opposed to dirt? There is a tapered roller bearing at the bottom of the spindle which develops a scalloped wear pattern from constant pounding on a narrow front tractor. The bolt on the segment gear on top is a setscrew. You can block up the tractor, unbolt the bottom casting/spindles that the wheels attach to, and pull the unit out the top. Then check that bearing at the bottom.
Bill(Wis)
06-28-2006 21:08:46
It could be something you've been looking at but, if it's a narrow front, in most cases it's down on the bottom end. Play in mine has always been the key on the bottom of the vertical spindle. If you get it in time all you have to do is replace the key. Fairly uncomplicated but a manual will help.
