Gear Lube Overflowing
orange-mud
06-28-2006 20:20:00
Went to check the fluid levels on my wd-45 today. When I unscrewed the transmission/differential/transmission clutch fuller plugs the fluid poured out of each plug for about 5 minutes. Very milky looking//not what gear lube should look like. Had no problems with this issue last year. Could the hydrolic fluid be leaking into the gear lube cavities??Anyone had this same problem??
old
06-28-2006 20:55:45
 Re: Gear Lube Overflowing in reply to orange-mud, 06-28-2006 20:20:00
Sounds like you may have rain water comeing in from the shifter. My self I would drain it and when you do slowly remove the drain plug. I'll bet the first thing you see is water drippping out just before the plug is all the way out
