allis b timing
trj
06-25-2006 11:23:56
fixing up my old tractor. it runs but #1,#4 plugs not firing.any ideas would be greatly apprciated.
old
06-25-2006 12:32:54
 Re: allis b timing in reply to trj, 06-25-2006 11:23:56
Could be bad plugs, or plug wires. Also could be the cap or rotor or even the distubutor shaft/bushings. Could also be a problem with the valves not opening as they should. Broken or bent push rods, broken rocker arms or even the adjustment screws have backed out and not opening the valves.
trj
06-25-2006 18:55:59
 Re: allis b timing in reply to old, 06-25-2006 12:32:54
thanks for the reply. plugs are new and thgere is spark on all the plugs.the rotor has quite abit of wear on it to the point that there is a little whole in it. I am trying to find a new one but not sure where to look.the push rods and rockers are all in good shape.i think ill try re-setting the adjustment screws I don"t know why but I think that might be part of the problem.
thanks again.
old
06-25-2006 18:59:50
 Re: allis b timing in reply to trj , 06-25-2006 18:55:59
From what you say it sounds like your cap and rotor are probably bad. Is this a mag type systm or a distubuto type of system. If its a distributor system any good auto parts store should be able to get you the cap and rotor. I get tractor parts from Oriellys all the time.
trj
06-25-2006 19:23:12
 Re: allis b timing in reply to old, 06-25-2006 18:59:50
I will change both once I find one.I live in canada and its hard to find parts some time.let me know if you have heard of any where in canada to buy parts. thanks again
old
06-25-2006 21:03:04
 Re: allis b timing in reply to trj, 06-25-2006 19:23:12
Well since I'm way down in Missouri I don't know of any place to get parts up your way. But I do know you could order them from this site and or from value----- ----bilt. If you want more info on value B just drop me an e-mail and I'll give you there phone number
trj
06-26-2006 18:32:20
 Re: allis b timing in reply to old, 06-25-2006 21:03:04
found the parts today. put them on and started her up.runs better but as soon as I put it in gear the motor dies. it seems to me like it's not getting enough gas.any other suggestions would be appreciated. oh yeah before this problem started I was mowing hay with it and it was working just great. but then all of a sudden it would just run for about 20-30 min. and die. wait about twenty minutes and it was like it never happened. this was last week.
trj
06-26-2006 18:13:26
old
06-26-2006 18:57:53
 Re: allis b timing in reply to trj, 06-26-2006 18:13:26
You may have a codenser going bad or you also could have some junk in the fuel system. Either one will also cause you some of the problems your now talking about
