D17 hydraulic return
charlieLCDR
06-25-2006 11:04:55
I purchased a kit to convert my hydraulics from single port to two port so I could use double acting cylinders. Directions say to remove th 1/2 inch plug on the left side of trans and plumb return hose to there but I don't find a half inch plug on the left side of my series III. I was assured this kit would work on series III.
Can someone please tell me if I just don't see the plug or does the series III not have one?
Also if there isn't a plug on the left side is it possible to drill and tap the side of trans to pipe the return there?
Thanks for any help
Gatz
06-25-2006 15:12:45
 Re: D17 hydraulic return in reply to charlieLCDR, 06-25-2006 11:04:55
Charlie,
The D17 has seperate lube for the hydraulics and the transmission/rear end.
If there have been no modifications to the tractor to allow the 2 compartments to freely mix, you wouldn't want the hydraulic system dumping into the transmission.
I'm not sure what the SerIII has for a sump under the torque tube for the hyd reservoir, but if you're going to tap a hole for a return line, make sure you can get all the chips out. If it has a sump, you could easily remove it before tapping.
I did this to the SerIV I'm restoring.
Actually, it turned out for the better to remove the sump, 'cause the screen was almost plugged and there was a heckofa lot of metal fines inside.
There is a large donut-shaped magnet inside on the pickup tube to catch the fines and it was completely covered.
Here's a pic of the torque housing on the SerIV where I tapped an extra hole.
third party image
CharlieLCDR
06-25-2006 20:07:50
 Re: D17 hydraulic return in reply to Gatz, 06-25-2006 15:12:45
Garz
Thanks a lot for the info and picture.
Mine looks just like yours and I plan to do the same thing.
Charlie
