7060
Fred Lemka
06-24-2006 19:18:37
When working the tractor it speeds up then goes back to normal rpms then it will competly shutdown i have changed fuel filter checked fuel cap i have a drip on the bottom of the injection pump wondering if maybe something has gone wrong with it.
jim ball
06-24-2006 23:22:45
 Re: 7060 in reply to Fred Lemka, 06-24-2006 19:18:37
i have 7080 with early style square glass fuel filter. this method sucks fuel from tank into fuel filter into injection pump. the fuel level
is below pump. i live on hillside ground and have
noticed that if on slope and tank is less than
1/3 full i get poor performance. i try to keep
tank over 1/2 full. i plan on upgrading to stanadyne newer version with electric pump that pushes fuel from tank into spin on filter into
injection pump. see parts manual or sales lit.
i can send a pic if you want. have you checked for air leaks on lines with soapy water ? when was the last time that you
are injectors & pump serviced ?
Fred Lemka
06-25-2006 19:59:37
 Re: 7060 in reply to jim ball, 06-24-2006 23:22:45
Thanks for the info on my 7060 fuel problem i found that it was just air in the injector lines.
Fred Lemka
06-25-2006 20:08:27
 Re: 7060 in reply to Fred Lemka, 06-25-2006 19:59:37
Have you had any problems with your hydralics. My pto kicks out when i lift&lower my lift like when I`m mowing hay and i lift it to turn around thats when it kicks out.
