Final drive leak 1939 B ??
Mark Kluber
06-24-2006 15:18:45
I replaced a leaking final drive gasket on my 1939 B. I used black silicone to seal it. The problem seemed solved, but after a week of no leaking it IS leaking again. Suggestions?? I really cleaned off the old gasket on both the housing & pan before I put the new on. I didn't pull the wheel off when I replaced it. Thanks
jeffalex2
06-25-2006 18:10:19
 Re: Final drive leak 1939 B ?? in reply to Mark Kluber, 06-24-2006 15:18:45
Some silicones won't keep a seal near oil. They get 'slimey' and then leak. Make sure you have a permatex form-a-gasket product that's designed for contact with oil, and, follow directions. Some say to let it get semi-hard and tacky before assembly.
