1939 B Oil Pressure ?
Mark Kluber
06-24-2006 15:10:06
I found & purchased my grandpa"s "39 B and had it restored. The man I purchased it from had already replaced the rings, ground and seated the valves, replaced rod bearings and clutch disk. I have a new oil pressure gauge. The compression is good and the tractor does not smoke. Using the tractor today to hill potatoes the needle in the pressure gauge stayed at the "N" or a little below. The oil level was 3/4 full. Is the oil pump going out? What else could be causing it?
If it is the oil pump what cost at I looking at to have it replaced? Any one near Cedar Rapids Iowa do this work? Thanks.
RandyN (MO)
06-27-2006 16:40:06
 Re: 1939 B Oil Pressure ? in reply to Mark Kluber, 06-24-2006 15:10:06
Using pleasted paper type oil filters will lower the oil pressure reading, too.
RandyN
chalmersbob
06-24-2006 19:20:54
i use 14w40 mulitweight oil in all my old ac's have also used 10w30 without any problems. Bob
old
06-24-2006 15:35:25
What type of oil do you have in it. If you have a muti weight oil then the oil could be your problem. In these old tractors I never use a muti weight oil because of that type of problem
