1947 WC Allis Chalmers Leaking Lower Radiator Hose
Chuck and Mike
06-24-2006 11:44:40
We have a 1947 WC Allis Chalmers that we just replaced the radiator and hoses on. We cannot get the upper (water pump side) connection to seal. We have tried using two high torque hose clamps (4x the clamping strength of a standard hose clamp) but still cannot get it to stop. We even installed a longer hose with and little bit of Permatex 'Form-a gasket' sealant, but that did not work either. The leak is not bad - it just slowly seeps out. Does anybody have any ideas on how to fix this? Any help would be greatly appreciated.
Thank you! Chuck and Mike.
BCnT
06-24-2006 20:19:42
 Re: 1947 WC Allis Chalmers Leaking Lower Radiator in reply to Chuck and Mike, 06-24-2006 11:44:40
you sure the water pump aint seeping and running down hose?
Mark - IN.
06-25-2006 21:24:25
 Re: 1947 WC Allis Chalmers Leaking Lower Radiator in reply to BCnT, 06-24-2006 20:19:42
When it happened to me, thought was a loose hose or corroded snout, but wasn"t either. Got gasket material, Permatex No.2, took the pump off and apart, cleaned it up and made a new gasket for the pump casting to plate and one for the plate to the engine block, and hasn"t lost a drop since.
Mark
Joe M(GA)
06-24-2006 13:09:29
I'd be looking for a crack in the neck. Also clean off the permatex, look for the crack or rust pin hole, then get some seals-all or 3-m yellow weatherstripe glue and just barely coat the inside if the hose (cleaned and dryed)re-install. let it sit and dry a day with the clamps on. Then re-fill and check.
