Steve@BB
Rod (NH)
06-22-2006 17:48:55
Steve, I have a question on a mag I've been using on my '42B. It's an FMX and I noticed the label plate has a "15" on it. It would seem this is the lag angle but it is not identified as such. I've been using it on my B for a couple years now with no noticeable difference from the original FMJ that I presume has a 30 deg lag angle. I have never checked it with a timing light and it appears to wind up in the exact same position as the FMJ when doing a static timing setup. Here's a picture of the label plate:
third party image
Do you think the 15 is the lag angle? What else could it be? If it is a 15 deg lag angle, what changes do you think would be involved in converting the mag to a 30 deg lag angle unit?
Thanks,
third party image Rod
Steve in N.J.
06-27-2006 17:31:58
 Re: Steve@BB in reply to Rod (NH), 06-22-2006 17:48:55
Hi Rod!
Sorry it took me so long to respond. I don't visit this site as much as I used to. You are absolutely right about the 15 stamped in the I.D. plate on that particular mag meaning the rotation or lag angle, and in reading your second post, you confirmed that. Looking at the 16A-1 vendor # on the tag tells me that's F/M's customer number for Lincoln engines. These particular 4 cylinder engines run a 15 degree lag angle, and as you can see have a clockwise (CW) rotation identification as AC built units do with your particular engine. The internal parts of that 16A1 unit utilize the exact same parts as your "J" 4B3. Even the Impulse is the same S2563C type impluse unit that I use in rebuilding the popular "J" & "X" series units that AC required for their engines. Obviously, the unit works quite well in your application which I figured would, because the small difference in the rotation angle doesn't effect the running of the engine at all. It only pertains to the 0-400 rpm area. If you would like to learn a little more about rotation angles (lag) give me a call at the shop. Be happy to explain how the system works. It's easier to explain it than type it... LOL!
Steve@B&B
Bob
06-22-2006 23:55:05
It's been a while since I've dealt with this, but wouldn't 15 degrees at the mag give you a 30 crankshaft degree advance, which is about a typical spark advance?
Rod (NH)
06-23-2006 10:19:48
 Re: Steve@BB in reply to Bob, 06-22-2006 23:55:05
Hi Bob,
The impulse coupling rotates at crank speed. This can be determined by inspections of the crank drive and camshaft and magneto driven gears. There is a 2:1 speed reduction in the magneto itself such that the actual rotor rotates at 1/2 crank speed, as it should. As far as I know, any lag angle is built into the design of the impulse coupling or how it interfaces with the rest of the magneto. Whatever lag angle exists is only functional during slow speed cranking during impulse coupling windup. The feature is disconnected and has no function at all once the engine has started and is running. The engagement fingers are prevented from contacting the stop by centrigual force. It is a means to retard the spark during starting only. At least that's my understanding of it. My older FMJ mag has no label plate designation of a lag angle but I am presuming it has a 30 deg lag built into the impulse coupling since the flywheel fire mark is 30 deg before TDC. I have not disassembled both mags and compared the impulse couplings. I almost always setup my mag-to-engine timing statically using the "impulse coupling trip" method and TDC on the flywheel. With that method, the impulse coupling trips and #1 plug fires at TDC of #1 cyl on compression. Both the FMJ and the FMX perform exactly the same in that regard. What I haven't done is verify the running timing with a timing light and the flywheel fire mark. It may, in fact, be firing at 15 deg before TDC rather than 30 while running and I simply don't know about it. It seems to run OK though if that's the case. The belly mower is mounted and the support bracket covers the timing opening. I just haven't taken the time to remove the bracket and check the running timing. I did remove the impulse coupling from the FMX this morning. On the back side of it is stamped "R15°", which, I presume stands for retard 15 degrees. That confirms the 15 on the label plate. It also would seem that you could change the lag angle simply by replacing the impulse coupling with a 30 deg one. Perhaps there is some error in my thinking on all this and I'm open to any comments.
Rod
