engine shut down
hillbillyhaven2
06-21-2006 09:17:12
my dad and i just getting started in the old tractor scene. we have a 1953 wd that seems to run really good until it heats up then justs shuts down. already rebuilt carb and put new fuel line with in-line filter. any help would really be helpful. thank you
Steve in N.J.
06-27-2006 20:06:10
 Re: engine shut down in reply to hillbillyhaven2, 06-21-2006 09:17:12
If your fuel flow has checked out okay, and your tractor is mag fired, it could possibly be the coil giving you the problem. Most WD's if mag fired were equipped with a "J" series Fairbanks magneto. The early production mags were equipped with a tar/taped coil. These coils after many years of service start to leak and break down, especially when they build up some heat in them from service and from the engine. The coil grounds itself out on the inside of the housing and spark is lost. After it cools off, the engine will fire right up again like nothin' happened. If you do have a "J" series mag (2 piece- lower cover & upper cap) take the 4 screws out and lift the lower cover up to inspect what type of coil it's equipped with. If it's the tar/taped version, that's probably the culprit. If it's a Maroon or Reddish Orange color, it has the better epoxy sealed coil in it which is the upgraded version. In that case, it could be the condenser causing the problem. If you need a replacement coil or components for your mag, we're a Fairbanks dealer and repair center and can help you out with anything you may need to get yer' tractor back in service...
Steve@B&B
Ted In NE OH
06-23-2006 09:21:58
If it does it under heavy load check for a good furl flow by removing the sedimate bowel. Could be dirt and crud in the bottom of tank restricting fuel flow. Another thing that will stop an engine when hot is insufficient walve clearence, check compression when cold and again when hot..
slowsmoke
06-22-2006 16:16:57
does it have oil pressure?
souNdguy
06-21-2006 17:41:46
Why speculate.. start diagnosing.
Next time she stalls, first check spark... if spark is ok, check fuel flow thru carb float needle.
post back if ya need more help.
Soundguy
BCnT
06-21-2006 10:09:17
sounds like a bad coil or condensor to me.
old
06-21-2006 09:20:11
Go out and get it to the point that it shuts down on you and then check to see if you have spark right after it stops. I'll almost bet you will find either a weak yellow spark or no spark. Your problem most likely is that your coil is going bad.
