WD allis pulling haybine
Mike Kunz
06-20-2006 12:42:05
Would a WD pull a 479 haybine (9 foot) ok or would i need a bigger tractor?
Dairy Farmer
06-22-2006 07:48:09
 Re: WD allis pulling haybine in reply to Mike Kunz, 06-20-2006 12:42:05
it should have no problem, we cut with a wd and an International 990 9 foot haybine and it goes fine as long as you're in first gear all the time.
Joe(TX)
06-21-2006 05:14:59
A WD should be able to handle it. My brother has a WD and a D-15 and they handle his 479 with problem in 6 ft high sudan grass. They both pull it as fast as the cutter will cut. Last I looked both were over 35 hp wich is what the minimum for the cutter is said to be.
Teddy (punchie)
06-20-2006 23:42:11
HI I would think it would be hard on the old girl. If you are cutting a few acres at a time and hay is around 90 bales to acre or just under 2 tons / acre I would give it a try, set her to cut around 3 " or higher. Make sure she is sharp and field ready from top to bottom. Teddy
Tramway Guy
06-20-2006 16:25:52
It might do it if there was a gear slower than first gear....but there isn't.
hd6gtom
06-20-2006 15:38:26
I have a neighbor that pulled his 488 newholland haybine for 1 whole season with a wd45. His 190 gas was in the shop waiting on parts. It worked ok.
old
06-20-2006 13:33:25
I would guess it would do ok if the hay isn't to heavy and you go slow. I use a NH460 that is 9 foot and pull it with an Oliver 77 which is 38 HP and your WD is just a little smaller at around 34HP so it should do ok as long as you take it slow.
John (MO)
06-20-2006 13:28:06
A WD will pull a 9 foot haybine down a flat road fine. But, if you want to mow anything taller than yard grass with it, you`ll need a bigger tractor.
Dick L
06-20-2006 19:19:25
 Re: WD allis pulling haybine in reply to John (MO), 06-20-2006 13:28:06
Thats funny I never had any problems pulling my 9 foot haybine with one of my Oliver 77"s. Always drove in 4th gear.
