crank specs for a b
shaggy wc
06-19-2006 18:14:52
Can anyone give me the High and low Specs for 1940 aills b crank shaft
Earl-IL
06-20-2006 04:54:41
 Re: crank specs for a b in reply to shaggy wc, 06-19-2006 18:14:52
Shaggy, My Federal Mogul Bearing book states from serial #B64501 con rod journal ,1.9365 ----1.9375 Mains -2.249-2.250 .009 shim pack on rods & mains. Hope this helps. Earl
shaggy wc
06-20-2006 18:10:27
 Re: crank specs for a b in reply to Earl-IL, 06-20-2006 04:54:41
thanks thay will help
steve(ill)
06-19-2006 18:44:06
the main and connecting rod bearings should have .015 to .003 clearance on the crank. there should be .006 worth of shims on each cap. Normally three of .002 shim on each bolt. You can remove a shim or two to tighten up the clearances if needed. Main thing to measure is that the journals are round. if they are egg shaped more than .002 then you will have trouble using that crank. after setting each bearing clearance, roll the crank a couple turns to see that you still have easy turning before going to the next cap.
