Leaking tranny fluid from PTO - AC 170
bake5454
06-19-2006 05:59:31
My AC 170 is leaking tranny fluid from the PTO shaft. I'm assuming there is some type of seal around the PTO shaft and I was wondering if it was easy to get to by just removing the cover on the shaft. It has a pretty steady drip so if I don't get this fixed I won't be using the tractor much w/o constantly adding oil.
Eldon (WA)
06-20-2006 22:28:48
 Re: Leaking tranny fluid from PTO - AC 170 in reply to bake5454, 06-19-2006 05:59:31
Just changed one last month, took about an hour.....didn't drain the fluid first but probably should have as it runs out thru the bearing. I caught it with a flat pan, but there is a lot in there. Anyway, take the cover off and the seal can be tapped out of the cover. Use the old seal and hammer to set the new seal into the cover. I just happened to have a NOS seal in my stash of NOS parts....it is a neoprene lip seal with a felt backing. The one I took out was a cheap neoprene lip only and obviously didn't last very long. I believe the proper seal is still available from Agco for around $17.
