WD-45 RAD.
WCPULLER
06-18-2006 19:46:41
IN NEED OF A WD-45 DIESEL RAD CAN ANYBOBY HELP. OR A PIC OF A WD-45 DIESEL RAD
Jerry(mo)
06-19-2006 06:58:01
 Re: WD-45 RAD. in reply to WCPULLER, 06-18-2006 19:46:41
The wd45 & wd45d Radiator are not the same. The wd45d is twice the rad with another row of fins and the bottom hose is on the left side, instead of in the middle like a wd45. The wd45d will be hard to find and will cost twice as much.
Link loading="auto" style="width:auto;height:auto" alt="Third Party Image">
Texas Denny
06-19-2006 10:50:10
 Re: WD-45 RAD. in reply to Jerry(mo) , 06-19-2006 06:58:01
I read the catalog wrong. I also checked some pictures of my D-17 and verified that my diesel radiator has the lower connection the same as the one in your picture. There are two D-17 Diesel radiators listed. Through serial number 38964, the part number is 0229704-2. Do you know if that number matches the one for the WD-45 Diesel? If they are the same, there were a lot more D-17 diesels built and should be more in salvage.
Texas Denny
06-19-2006 06:29:58
The D-17 diesel and gas tractors used the same radiator. Since there is minimal difference between the 45 engines and the D17 engines, I would expect the same for the radiators.
John (C-IL)
06-19-2006 07:27:13
 Re: WD-45 RAD. in reply to Texas Denny, 06-19-2006 06:29:58
The D17 bottom outlet for a gas tractor is on the right. Don't know about the diesel.
old
06-18-2006 20:31:01
Well till you said diesel I could have helped you out. I have one or 2 radiators from WDs but they are for gas tractors and not sure if they are the same or not. I know the catalog I have doesn't even list one for your tractor but does for the gas tractors. Sorry I can't help
Texas Denny
06-19-2006 06:36:11
 Re: WD-45 RAD. in reply to old, 06-18-2006 20:31:01
Old, read my other post. I think the radiators are the same.
old
06-19-2006 09:06:02
 Re: WD-45 RAD. in reply to Texas Denny, 06-19-2006 06:36:11
What other post. I know the value----- ----- -bilt catalog doesn't even list a rad. for the diesel tractor but does for the gas and thats why I'm not sure if they are the same or not
Texas Denny
06-19-2006 10:40:44
 Re: WD-45 RAD. in reply to old, 06-19-2006 09:06:02
Another post says that the WD-45 Diesel radiator is different than the gas and shows a picture of the diesel radiator. Odd that they are the same on D-17 gas and diesel. The radiator on my D-17 does not look like the radiator on the other post here for the 45 diesel. Looks like there is a vertical connection at bottom instead of horizontal like on my 45 gas and my D-17 diesel. Must have been an interference problem on the 45D that was avoided on the D17D. I learned something today! Again!!
