WD labors bad.... and more
uhoh
06-17-2006 20:26:36
recently had a friend purchase a WD. has 3" straight stack, so it tells all. it is laboring somewhat, and there is a pretty well constant blue flame coming out of the stack. rebuilt the carb (tisco kit) and tried every adjustment there and moved the mag to change timing. it still labors and runs rough. strong power crater motor (so the sticker says), no smoke, very sharp governor, but where am i going wrong? thanks in advance for any help.
BCnT
06-17-2006 20:39:51
 Re: WD labors bad.... and more in reply to uhoh, 06-17-2006 20:26:36
have you set the points??? that will screw with timing... also F/M mags have a set of gears that can get out of time if mag has been apart...if tuning doesnt help and this engine has been apart i'd look at timing gears.
