180 Diesel
Bill 180
06-16-2006 20:05:32
I have a 180 with 1 set of hydolics. I have installed a loader on the tractor and need to plum into the tractor somewhere so that I can get fluid to the add on two unit valve. I need help in the best location to plum into the hydrolics. Any advise would be appreicated.
Joe(TX)
06-19-2006 15:46:22
 Re: 180 Diesel in reply to Bill 180, 06-16-2006 20:05:32
One way is to buy a new 2 spool open center valve with Power beyond for the loader. Be sure it has a power beyond outlet. Replumb the supply line going to your old valve to the new valve first. The power beyond port of the new valve then runs to the old valves inlet. You will need to run a return from the new valve to the reservoir.
JMS/MN
06-17-2006 11:04:22
For an immediate solution- use quick couplers on your add-on valve and hook into the existing remote couplers. That original valve will have to be activated to use your add-on, but can be inactivated when not actually using the loader valves.
