WD throttle linkage
lminch
06-15-2006 07:50:36
First of all I want to thank everyone here for all the good info. Now have the WD running but it is sort of like plumbing. Once you get one thing fixed you move down the line. My question is why does my throttle handle bind the more I try to advance it. From what I have read I may need the spring and bushings to hold but I really have to apply some force to give it the gas. Throttle seems to attach to what seems like the old mag ( I think?) before routed over to the carb. That is the only place I can see it might bind. It has been converted to 12 v. though. Any help appreciated
jpscny
06-16-2006 09:23:44
 Re: WD throttle linkage in reply to lminch, 06-15-2006 07:50:36
if I remember right a rod goes thru a tube across the front of the engine you may have to free that up.
lminch
06-16-2006 10:03:31
 Re: WD throttle linkage in reply to jpscny, 06-16-2006 09:23:44
thanks jp, I will look at it tonight
lminch
06-16-2006 06:05:26
Sid I was wondering if that was the govenor after reading a bit. I have not removed from govenor yet. Is that just a matter of a pin? If it is the govenor binding what do I look for?
Thanks
Lynn
Sid
06-15-2006 21:48:05
"Throttle seems to attach to what seems like the old mag ( I think?)" That is the governor. Have you disconected the linkage from the governor to the carb to see if it is still binding?
Sid
06-15-2006 21:48:09
