WD to 12 volt?
chalm
06-13-2006 14:17:50
I am looking to switch my WD to a 12 volt negative ground. I can't find any kits for A/C. I have a delco alternator with internal regulator but was wanting to convert the ignition from mag to electronic. What coil do I use? Do I need a whole new distributor? Is there a place to look? Or should I just keep the old Mag system (which works but needs the distributor timed). help please.
Steve in N.J.
06-17-2006 07:19:16
 Re: WD to 12 volt? in reply to chalm, 06-13-2006 14:17:50
Chalm,
We offer numerous different kits for 12V conversions for your WD. Also have all the correct parts to upgrade from Mag to Distributor w/electronic Ignition. We carry a complete line of our own plug wires and Ignition parts for the the 12V conversion. Drop us a line or give us a call. Be happy to help you out... Thanks Dale for the referral!
Steve@B&B (973)697-5747
souNdguy
06-15-2006 06:39:43
NAPA IC14SB is a decent ( * NO RESISTOR REQUIRED * ) coil for generic 12v applications.. however.. many electronic ignitions will specify the use of a different coil.. or a 'hot' coil.. etc. So I'd get a coil based on the ignition makes recomendations.
Another option is to 'butcher' your mag, use it's points and wire in your own coil.. etc... I've sene that many a time on various tractors... In that case.. the coil I mentioned is fine..
Soundguy
DaleS(WV)
06-14-2006 13:02:40
Try Steve at B&B Custom Circuits.
Phone: 973-697-5747
Has 12v conversations for AC tractors and
very knowledgeable.
